RCU Forums - View Single Post - Wing jig question for friend
Old 02-10-2009 | 01:18 PM
Campgems
Default RE: Wing jig question for friend
ORIGINAL: wzak29
I am the friend that’s building the wing.
Campgems :
You are correct about the dihedral is set on the previous step with epoxy and 6 hard wood joiners it’s not going to change. The washout jigs are angled as to put a twist on the wing they don’t set or change the dihedral. If the root is pined to the table why should it make any difference if the wing is 1”. 3” or 5” from the table the washout angel will not change.
You just summed up what I was trying to get across. It's all relationship between the tip and the root. the height above the table doesn't matter. Keep it as short as possible to make the work eaiser.
Don
