OK, how smart are you?
Do you have a scroll saw or a band saw, a table sander, a truly flat surface to build on, enough room to move about a 1/4 scale airplane, know how to use all different types of glue (aliphatic, cyanocrylate and epoxy), covering iron and heat gun and of course an Xacto # 11 blade, one in the knife and 99 others awaiting in the box, if yes to all of the above, you are not only smart but wealthy (by modeling standards, of course) and I would tell you to go ahead and start this project, these Cubs are not difficult to build (Sig's instructions are the best in the field), but they do require a lot of cutting, fitting, some more cutting, sanding, etc. I am sure that by having these tools you would be embarking in a very satisfying project, after all, you are a very smart guy! (It is all said in a jokingly manner and in a spirit of camaraderie and I am a teaser by nature)
Good luck on your project and if you need some advice you can always email me!
