RCU Forums - View Single Post - How do i unseize an engine?
Old 02-11-2009 | 03:56 AM
Ram Jet's Avatar
Ram Jet
Default RE: How do i unseize an engine?
ORIGINAL: AnAlternateEgo
I recently purchased a package of used planes from a man. One of the planes was a .60 Piper Cub. When i first looked at it the prop was stiff but it was moveable, brought everything home and started working on loosening them up and now it seems to have only gotten stiffer. I have removed the glow plug and sprayed the system with wd-40 but still no luck. What do you all suggest i try next?
I've read a-lot of threads here where many members recommend a good soaking in methanol fuel to loosen up old congealed castor oil. I would guess denatured alcohol would be effective also. Lacquer thinner would do it but you risk ruining any rubber or silicone sealing gaskets.
Bill
