RE: what type of solder to use
Electronics solder, rosin core, will work. However, it needs extra flux pre-added to the part.
The StayBrite silver solder is the bomb, though! It works perfect, holds together metals that otherwise you would not be able to solder, and you can use a soldering iron to work it and you do not need a flame torch.
