RCU Forums - View Single Post - JetJoe OWNERS thread
Old 02-11-2009 | 03:10 PM
  #1926
bukeym
Default RE: JetJoe OWNERS thread
Hi everyone,
Attached you can see the photos of the combustion chamber of my JJ1400. I am experienceing high temp problem at high RPMs particularly after 130K. I have checked everything: 1. Balance is perfect 2. vaporizer tubes tested with propane not much difference 3. Startup perfect temp not over 450-500 C. 4. Bearing conditions are OK. 5. Compressor clearance is even perfected with sheets of hysol layers.
So I believe there is only one problem left: Poor vaporisation!... Am I correct?.. I see that the vaporiser tubes are way too short and away from the combustion front cover..I would appreciate some input. Can I find vaporiser tube circle similar to MW 54 ?. Does anyone have spares or any contact for supplying?.
ID:	1132988   Click image for larger version
ID:	1132989   Click image for larger version
ID:	1132990   Click image for larger version
ID:	1132991   Click image for larger version
ID:	1132992   Click image for larger version
ID:	1132993   Click image for larger version
ID:	1132994   Click image for larger version
