RCU Forums - View Single Post - Nitro Engine Troubleshooting and Tuning
Old 02-11-2009 | 05:33 PM
  #49
rjsdad
Default RE: Nitro Engine Troubleshooting and Tuning
the rpm should raise a 1.5-2 seconds then shut off. If you are doing the pinch test and the rpm does not increase then you are running to lean. This is not good for the engine. Also look at your glow plug, if the coil are white then it is running hot (lean) The fuel is a lubricant as well for the engine.
