RE: NEUTRINO - NEW F3A PROJECT FROM GREECE
Hi
Guille !
Your ideas and knoledge seem to be the best method available now ,I think this will be my next step ,(maybe in 6years..)But in order to do that you need to be expert in 3d design ,as you can see in my post I stuck in the surfaces of complicated curves and all that ,I`ll need a couple of years till that.Then you need a big mill or cnc router ,I would have to split my fuse in 3 parts to mill it with what I got available ,but I guess this is possible.I share the same ideas about pattern plane designs ,all of them are trying to achive the same performance with the same equipment available.
Now ,as the first halve of the mould cures ,I did some progress on the stabilizer .Pictures tell 1000 words so here it is..
I use steel plates as rulers for cutting the foam both for shape and airfoil ,needles to say I trust my workbench 100% that is 200mm thick MDF sandwitch with cross ribs.
