RCU Forums - View Single Post - CA HINGE INSTALL HELP
Old 02-11-2009 | 06:24 PM
planer1
Default RE: CA HINGE INSTALL HELP
Well with all the good advice, I CA'd my first set of hinges on the wings. Guess I'm a rocket scientist now. Anyway, I followed the instructions to a T and things went smooth. A couple of things I found to work for me was to tape the aeleron in the flexed position which was just one less thing to concentrate on. Also, after drilling the the first small hole in the slot for wicking purposes, and having problems centering it, I found if you first insert the very end of a pen into the slot, it centers a starting point for the bit, allowing a very centered and straight hole. Guess I'll see how strong it is when the bird takes flight, but now it feels and appears to be nailed.
Thanks to all for the patience and great help.
