RCU Forums - View Single Post - I beams as shear webs
Old 06-09-2003 | 12:25 PM
BingoFlyer's Avatar
BingoFlyer
Default I beams as shear webs
Steff,
I use both methods of construction depending on the configuration of the wing. If the wing is sheeted between the LE and Main Spar I glue the shear webbing to the back of the spar, if the wing is open between the Main Spar and the LE as on my "Bingo" I use the I-Beam.
I have been building this way for more than fifty years and have never had a wing failure. Using the D box construction (sheeted between Spar and LE) is much easier and faster to build.
