RCU Forums - View Single Post - I beams as shear webs
Old 06-12-2003 | 10:43 PM
JimTrainor
Default I beams as shear webs
Here is an example of some simplified stress calculations for a model glider wing (courtesy of Dr. Mark Drela):
http://www.charlesriverrc.org/articl...par_sizing.txt
The numbers in the example are for a winched launched 2 m glider.
The shear load (at the wing root) is estimated to be 80 lb. The tension and compression in the spars (as a result of the bending load at the root) is estimated to be a whooping 1733 lb. Yikes!
The spars in the example are carbon wrapped balsa. There is another article somewhere on that site concerning their construction and testing.
There is a note at the end of the article about wooden I-beams as well.
