RE: flutter problem...
Check all of the connections for slop. Worn clevises, Servos with slop in them, too much freeplay in the hole in the control horn etc will all contribute to flutter. If there is any slop - correct it.
also -
Are you trying to fly the plane fast?
Is the rudder centred for straight flying or is it offset a little to compensate for some other airframe characteristic?
