onewing:
If you don't mind a "Stick" plane, the "Joss" stick from Hobby people is nice, the Ultra Stick 60 would work well.
If you don't mind building there is the "Killer Stick" from Northeast Aerodynamics.
Engine Requirement: .61 to 1.08
Wing Span: 81”
Wing Area: 1303 sq. in..
Fuselage Length: 69.5"+ Engine
Weight Range: 8.0 lbs
Radio Functions: 4-8 channels
http://www.ne-aero.com/killerstick.html
Highly recommended, big, but light. Size of the UltraStick 120, but the weight of the US 60. Your 120 should hover it with no problem, and accellerate vertically from the hover.
Not the cheapest, $149.95 plus $15 S&H to your door, also far from the most expensive. And it's far nicer than any ARF.
Bill.
