RCU Forums - View Single Post - keel weight, help needed
Old 02-12-2009 | 06:34 AM
mfr02
Default RE: keel weight, help needed
The overall weight will be in scale, but on a model we can distribute the weight differently to that on the original. Build the hull and everything above the waterline light but strong, and make sure that ballast weight is as low as possible to lower the CoG. If required, you can always extend the depth of the fin mounting the ballast.
