megatech m46 engine problems
The tank can also empty to "half" though a syphon in to the carb. The tank will empty until the fuel level in the carb matches the spray bar.
Still, DBCherry is likely right, and you should take out the tank and inspect it, espeically because you are having engine run troubles.
