You can add some light weight oil to the joint AFTER soldering with Stay Brite to preclude the rust. The flux is what causes the rust, it is a very strong cleaner and eliminates all the oil on the surface.
Good luck to you guys using electrical solder on mechanical joints, it will bite you right in the bunners some day when you least expect it.....
