RCU Forums - View Single Post - CMPro Swallow EX 90
Old 02-12-2009 | 04:10 PM
  #35
BaldEagel's Avatar
BaldEagel
Default RE: CMPro Swallow EX 90
Look closly at the weight issue and the C of G with that weight of engine, you may need to put the elevator servos at the rear to compensate, I had to do that with a 2S 91 in mine, look bach through the thread and you will see how I did it, I also moved the rudder servo boack and forth to make sure I got the C of G correct without adding unnecessary weight.
Mike
