ORIGINAL: brett65
It sure does look nasty in that first pic, was tight bond the only glue you used on it?
I used 30 min. epoxy on the Firewall and the wing mounting blocks, everything else is titebond II.
The first picture is what it looked like with no glue. on the first kit I was able to straighten it somewhat but I didnt like it so CarlGoldburg suggested sending back to them.
There is just not enough horizontal surface in the front half of the kit to hold things in alignment for set up...
Why do you ask about the titebond II? I like the time it gives me, especially in this instance where I had to keep checking alighnment as it set up...
Steve
