RCU Forums - View Single Post - Is it possible to read mah using a multimeter?
Old 02-12-2009 | 09:38 PM
Access
Default RE: Is it possible to read mah using a multimeter?
You need a multimeter, a constant current load, and a stopwatch, and then you could do it. You could in theory do it with a normal resistive load but then it's a calculus (area under the curve) problem and the math is beyond most people.
