RCU Forums - View Single Post - Is it possible to read mah using a multimeter?
Old 02-12-2009 | 09:54 PM
500 lb. koolaid man's Avatar
500 lb. koolaid man
Default RE: Is it possible to read mah using a multimeter?
ORIGINAL: Access
You need a multimeter, a constant current load, and a stopwatch, and then you could do it.
I'll skip the calculus option
So I have the battery under a load with the multimeter on it set at 200ma which is the best setting for it... and the clock keeps track of drain time or what. I'm confused so please elaborate. Thanks.
