RCU Forums - View Single Post - Newbie Question about plane weight
Old 02-13-2009 | 09:23 AM
mclina's Avatar
mclina
Default RE: Newbie Question about plane weight
The stick on lead weights are probably the easiest way to add weight to the nose. You may also want to see if you can move your engine forward on the engine mount by a small amount. It is a little bit of work, but it might save you from adding weight.
Good luck
