RE: Official Smartech Thread
the shocks will have no effect on ride height. the height is usually changed by turning in or out set screws in the lower arms. once the screws are backed out enough the arms rest on the chassis which is as high as it will go with bending the chassis itself. The tsais rear exhaust wont help....after looking the rear tire would hit the manifold...just be changing one problem for another.
I do have another idea for you though....they make aluminum wheel extensions that will fit these. i think they are 1"-1.5". Ill hunt down a link for you but i think that will be the easiest route to go.
the bell and gears i used were from hpi on the car in the first pic....heres the numbers
HPI Nitro 3 RS4 RTR Threaded Clutch Bell 2-Speed 86039
HPI Alum Pinion Gear 23T # 76983 for Nitro RS4 3 18SS
HPI Alum Pinion Gear 18T # 76978 for Nitro RS4 3 18SS
heres the wheel extensions too
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS
copied titles from ebay if you wanna see the parts...should just need to copy and paste....hope this helps
