RE: Another brushless 'myth', lower KV = more torque
Everything you are talking about is unloaded first of all. Next, you must consider the physics of torque of current carrying coil. You already admit that the torque is proportional to the number of turns, this does not change. Also, the duty cycle can be 100% and the rpm of the motor does not have to be at its max RPM due to that very loading that you haven't taken into consideration.
