RCU Forums - View Single Post - CMPro Extra 330L 50 size
Old 02-13-2009 | 10:57 PM
  #96
Craig 01
Default RE: CMPro Extra 330L 50 size
Hi Fellas,
Ive had the red version of this for quite some time and have started setting it up.I have started to fit up a Saito .82, left this stage to last.
I've a question you might be able to answer.
Where did you set your engine thrust angles to that suits this extra or did you set exactly as instructions show with the centre lines offset 4mm above and to the left with the 2 washer thickness packers under the left side of engine mount lugs ?.
Cheers,
Craig
