Charging a LiPo
I have a Blade Dancer EPP that I put together last week. The battery I have for it is an Electrifly 1500 mah 3 cell. There is a sticker on the battery that, among other things, says not to charge it through the discharge leads, but to use the balance leads. That's fine, except it takes forever using the "wall wart" charger that came with the battery pack. By the way, the battery pack came with that Diablo I've been talking about in previous posts.
Well, I guess I'm somewhat confused because the rapid field chargers connect to the discharge leads, right? If so, then how do we safely and correctly charge this battery using the balance leads?
CGr
