ORIGINAL: europatc74
Your CG should be 4 3/4" from leading edge at Fuse. Very important that you balance laterally. Remove the prop. Set the prop shaft on a flat object. Raise plane from the back at center point to level position, check and adjust lateral balance.
Thanks for the info..Been looking forward to flying this thing..
