RCU Forums - View Single Post - Is all thrust the same?
Old 02-14-2009 | 03:30 PM
Robrow's Avatar
Robrow
Default RE: Is all thrust the same?
I like your analogy Woketman
Sean actually touches on something interesting which can also influence our choice....spool times and how quickly our engines produce that all important thrust, smaller engines in general do tend to require higher rpm to achieve similar thrust levels to larger dia. donkeys.
Though we are now starting to see the next generation of smaller engine emerge which is starting to address that with compressor wheels better designed for our application.
Rob.
