RE: what prop do i need
I am running a 12 X 7 on my OS .61fx.
Edit: You will need to pick up a prop reamer also as the hole on a standard prop is too small for the shaft of the .61. Do not try to make the hole bigger with a drill bit. The reamer has a slight taper on it, and will make the prop seat alot better on the shaft.
