RE: G62 Spring Starter Binding
you cannot wind them up tight. The spring coils go in between each other and rub the one way clutch and the shaft.
The front coil gets distorted and rubs the crankshaft and makes it hot. This melts the rear case seal and cooks the grease in you dog clutch one way bearing to where it freezes up
The bad seal lets air in the crankcase and your engine will not draw fuel
