RE: help on ideas the most aerodynamic shape
The pod definatly slows the air In the tunnel, no doubt. The tadpole or rain drop shape are my original thoughts but, after doing a airfoil test on this online simulator I was thinking about sort of a mirrored tadpole with the point coming Into the belly and going out.
I want to make this pad/pod as small as possible mostly rounded over. I like the leading sharp edge. Then again, the pod will need to cut through the water when It touches water... Hmmm...
