RCU Forums - View Single Post - Headaches with Glue
Old 02-15-2009 | 08:12 AM
Rodney
Default RE: Headaches with Glue
what pdm52956 said, if you are mixing in anything with a wax coating the epoxy may not set up properly. I have never had a problem with any of the epoxys not setting up properly, even if the mix ratio was off quite a bit. Temperature effects cure time a lot, the warmer the faster up to a point well above what a human can stand.
