RCU Forums - View Single Post - Hog Bipe Build - 2009
Old 02-15-2009 | 12:53 PM
SeamusG's Avatar
SeamusG
Default RE: Hog Bipe Build - 2009
Step 6: Tail wheel mount (TWM)
A new longer TWM was fabricated because the Sullivan TW is longer than the SIG hardware. Scrap 1/8” lite ply from kit waste was used. The Sullivan unit uses 4-40 bolts with blind nuts rather than machine screws.
Building Notes: I marked the TWM mounting hole locations by aligning the pivot point of the TW assembly with the trailing edge of the TWM. 1/8” pilot holes were drilled. The pilot hole locations were transferred to the FBR. The TWM guide holes were expanded to 9/16” to accept 4-40 blind nuts. The FBR holes were expanded to 7/16”. The blind nuts were glued to the TWM with 30 minute epoxy. I used the SIG 4-40 bolts and a hammer to seat the blind nuts. The TWM was glued to the FBR with 30 minute epoxy. Before clamping I inserted the SIG 4-40 bolts thru the FBR and into the blind nuts to ensure correct alignment when clamped. After clamping the bolts were removed. When dry I will run a 4-40 tap through each blind nut to ensure that there is no epoxy buildup.
TTFN
ID:	1136162   Click image for larger version
ID:	1136163   Click image for larger version
ID:	1136164   Click image for larger version
ID:	1136165   Click image for larger version
ID:	1136166   Click image for larger version
ID:	1136167   Click image for larger version
ID:	1136168   Click image for larger version
ID:	1136170   Click image for larger version
ID:	1136171   Click image for larger version
ID:	1136172   Click image for larger version
