RCU Forums - View Single Post - Hog Bipe Build - 2009
Old 02-15-2009 | 04:12 PM
SeamusG's Avatar
SeamusG
Default RE: Hog Bipe Build - 2009
Fuse Construction
Step 7b: Install other fuse side
Position and epoxy other fuse side onto 1st fuse side.
Building Note: Even though F-1 and F-3 are square to the 1st side, make sure that they are at 90 degrees to the 2nd. After applying epoxy and joining the 2 sides I had to add pressure on the front of the 2nd fuse to “push” the 2nd side back to ensure that F-1 and F-3 are at exactly 90 degrees. Again, I used flat toothpicks on the backside of F-1 to ensure that there was little or no gap on the front. I cleaned all of the joints with alcohol-dampened cotton swabs. I checked their alignment several times. I’ll recheck the alignment in 15 minutes to make sure nothing changes.
TTFN
ID:	1136322   Click image for larger version
ID:	1136323   Click image for larger version
