RE: 2 Axis gyro sources?
Hi Craig,
The CG shift turned out to be virtually a non issue. The changes in center of lift and staying within a reasonable static margin allowed the test model to fly with no problems. It required a bit of trim change but that was all. We had considered a sliding weight before testing but it adds unnecessary complexity and creates the possibility of problems if it fails.
Regards
Mike
