RE: Which Pull Start?
if you don't have the paitience for fixing it you better get a roto starter, but it's really not that hard to get the spring back in. just put the end into the casing and start wrapping the coil inside of the casing, instead of trying to wrap the coil tight enough, then trying to put it into the plastic casing
