T-34/85 Winter version with DX5e
Hey Guys,
The Winter T-34/85 has the Heng Long RX-14 upgrade and with the use of the DBCRC2 I am using the DX5e radio with the BR6000 receiver!
The main thing for this post is to show cases the DBCRC2 and its capabilities! Also I will be showing in what needs to be connected where,
and doing a couple of videos! One to show the functions and the 2nd to show the programming sequences!
You can remove the Heng long Rock, and just have the barrel cannon recoil!
You can have true inertia proportional drive!
You can add 3 unique sounds to your tank! Hit, Cannon, & Death sounds!
You can now use a Hobby radio now like the 2.4 GHz DX5e, to me, which is perfect for this DBCRC2 because it offers you 5 channels!
It is also a Tamiya compatible battle system, with 3 different weight class settings, and reduction in power to the tank as you take hits and LED registering the hits!
Now this is where I have done some thing unique and Blitzed out the tank! I have installed the DBU in the TC hatch and added some extra lighting! I still need to sand and repaint!
Here are some pictures of how it came together! The first and second picture shows how you can set it up with the standard Heng long receiver and radio!!
