RCU Forums - View Single Post - T-34/85 Winter version with DX5e
Old 02-16-2009 | 01:39 AM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: T-34/85 Winter version with DX5e
ORIGINAL: westdr6113
I like the hidden TBU, thats a cool idea. I recently converted one of these to HL electroncis also. But I used the orginal DBC. One thing I noticed thou was that the turret rotation and gun elevation motors were really loud, Even after I applied liberal amounts of lithium grease to the gears. Your's sounds alot better than mine in the video. Did you do anything to make them run better? It really does run alot better with the HL electronics thou.
Thanks, and it seems to be taking hits fine from all directions! And yes the HL boards are way better then the stock WSN,, even if you do not change out the gearbox,, I have some Gruapner 280's I am going to see if they fit though! See if it will help give it a little more power without thrashing the gearbox! On the turret rotation,, I swapped out the WSN turret motor for the Heng long unit! The elevation is the same, I did grease that up heavy
The Blitz
