ORIGINAL: RCKen
ORIGINAL: jib
Mix and match, but know that airtronics have different wiring, so you may need to swap leads in the plug to get everything working right.
Jack
This is only on older Airtronics servos. Everything that has been sold by Airtronics in the 5-6 years has had "Z" connectors on them which will allow them to connect to every other major brand. The easy way to tell is if the connector is black it's older Airtronics, and if it's a blue connector it's a "Z" connector that will connect right up.
Ken
AHHHHH!!!! glad to see that. These are the z-connectors
