RE: Top Flite 1/7 P-51 Build
All right, Sean! Yeah, my daughter is a lab rat for a doctor at UVA.
Did you ever get the engine running right in your Stik? If not, I still have my old OS 65LA which I'm not planning on using any more. You're welcome to it if you think you can use it. The LAs are good engines, but I don't care for them as the mid range is very difficult to get right, due to the low speed adjustment being an air bleed rather than a needle valve. Let me know if you want it, and I'll go clean the dirt off it from when it went in on the front of a Sig Cub.
Bring your Stik with you, you can fly as my guest.
Right now, we're planning on arriving the afternoon of the 24th, so I'll be at the field everyday at noon unless it's raining.
