RE: Jato Drive train
Several things may be happening. First check your clutch. My clutch went bad after I installed a new motor. Luckily I had a spare and so far so good. Also check the spur gear and the gears in the tranny to make sure everrything is ok. Also open you diff and make sure that is also ok. If you have any stripped gears they are not expensive to replace.
