Proper prop balancing
Got a problem with a Big Stick60. Having had the engine shut off right after take off three times this past saturday, the last time resulting in the landing gear removing itself from the fuselage. Did some investigating and found air coming through the fuel line. I know the system is tight so I must assume the air is from vibration. No room to cover the tank in foam. I bought a little smaller tank today and wrapped it in foam . I hope this helps. My question is, Reduce vibration and thus reduce airation in the fuel. When it comes to props where should material be removed from? Front, back or tip. I have the magnetic balancer and it is quite sensitive. I was wondering how to balance the spinner as well. Any suggestions would be greatly appreciated . Love this forum.
