RCU Forums - View Single Post - Official HPI MT2 Thread
Old 02-17-2009 | 12:14 AM
  #18947
nitro-rob's Avatar
nitro-rob
Default RE: Official HPI MT2 Thread
ORIGINAL: KeithjV
I like the GPM's. They hold up well and the larger bodies allow for more oil so you have better damping.
Nitro definitely get one of the 3 channel radios. For the few extra dollars its worth it, especially if you get a truck that uses the 3rd channel.
That clicky you are talking about is probably too tight of a mesh. Make sure the engine is straight too. Sometimes the mounting holes are slightly off and that causes the engine to be a little crooked. You should be able to slip a piece of paper between the CB and the spur and have it roll through smoothly without ripping when the mesh is set right. The spur gear could be out of round too, Ive seen that happen before. Sometimes they just dont come out right from the factory. If the mesh is wrong though you are going to destroy the spur in no time. I would make sure its right before you run it at all.
Also check the brake pad. Sometimes that gets out of line and that can cause the clicky feeling too.
GPM's can be bought for $14USD/pair with really cheap shipping on ebay. I've been following the ad and will likely upgrade this summer.
I played a lot with the mesh from very loose to tight and everything in between and it clicks the same regardless of the alignment and tightness. Its also only happens on the same two parts of the spur gear so I don't think its a mesh issue and think its just a bad spur gear. Its a minor click that was definitely not there with the 13T bell. The change in curvature of the larger bell seems to be magnifying a problem that was there for both bells. I will try running the truck slowly at first and if it burns the spur gear I think the problem will be fixed with a new one.
