RE: Torque Rating Question
One might care about the difference, since torque is a component of velocity. If, for instance, you crowed the ailerons / flaps on a glider at a certain velocity during level flight, it would require a certain amount of servo torque.
However, if the glider decended rapidly with the servos still locked "on crow", the likely increased velocity would cause an increase of force on the control surfaces, which could overstress the servo(s). Perhaps "Holding Torque" helps one determine if that's possible.
But what do I know?... I'm in Marketing (with an engineering degree)... lol
Best... Roger
