RCU Forums - View Single Post - BUSA 1/3 Sopwith PUP UK
Old 02-17-2009 | 05:31 PM
hurricane527
Default RE: BUSA 1/3 Sopwith PUP UK
well that was easy
some details then built to 1/3 scale using the BUSA kit as a base, it is being modified to some degree, it has a custom made scale u/carriage system that works as scale, the wing section has been thined to a more scale like thickness with no top spar now hence the scale working rigging, power comes from a G62 on an iso mount with hydraulic dampers, radio will be futaba 2.4 ghz, all the tail surfaces are renovable and have been modified again to a more scale like appearance, full working rigging employed again, time for more photo,s the cockpit this time first is the engine mount then the scale cowl mount under fus finaly rudder bar, joystick.
chris
ID:	1138261   Click image for larger version
ID:	1138262   Click image for larger version
ID:	1138263   Click image for larger version
