RCU Forums - View Single Post - Official Mayhem Thread
Old 02-17-2009 | 10:34 PM
  #1587
Rockman's Avatar
Rockman
Default RE: Official Mayhem Thread
You can put in any engine that lines up with the engine mount holes AND sits so the flywheel is not hitting the chassis. I would recommend a .21 to keep legal in case you decide to race. if you are only bashing, put the biggest engine in that will fit and line up. Check the fit if you use an electric starter on the backplate, sometimes the motor mounts sit the engine to low to allow for the backplate.
