RCU Forums - View Single Post - Fixing Avistar Horizontal Stab
Old 02-18-2009 | 03:42 PM
  #42
bruce88123
Default RE: Fixing Avistar Horizontal Stab
It will require more elevator to rotate for takeoff IF the CG is correct. If the CG is wrong all bets are off. Check and correct the CG if needed. Aft gear movement and tail repair will most likely cause a CG shift to the rear - not good if too much.
