RE: Fixing Avistar Horizontal Stab
You might try cleaning with alcohol after the initial windex wipe down if you want the patch covering to stick better. It has worked better for my repair patch jobs. For balance adjustment move the battery forward - it might fit under the fuel tank if needed without using additional weight. I have done that on a couple of planes.
