RCU Forums - View Single Post - Monokote woes
Old 02-19-2009 | 01:10 AM
Campgems
Default RE: Monokote woes
ORIGINAL: Gray Beard
Mike, I don't need to reshrink my planes from year to year with the Ultra. I have always lived in either Calif. or NV so it may not get hot enough in other states to do this. After I cover the plane I set it out in the hot sun and let it do the nasty ugly then bring it back inside to cool off. Then I reshrink it and do the sun thing again. It takes a time or two doing this but I end up with a covering job that stays tight, even when I went to shows for days on end with my planes out in the hot sun. This trick works even better with the Solartex covering. I just call this curing the covering.
Gene, I have always had car heat issues with the Monokote, Could be that the planes didn't last long enought to get the covering stablized though
By the way, I do like the color selection of the Monokote, and I use it for trim on everything.
Don
