RCU Forums - View Single Post - Pre-flight
Thread: Pre-flight
Old 02-19-2009 | 11:02 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Pre-flight
Throttle stick all the way down, the engine should run at idle. Bringing the trim all the way down should kill it.
Fill the tank by using a pump. Remove the fuel line from the carb and pump the fuel in there, then replace the fuel line to the carb.
Start the engine at about 3 clicks above idle.
Get help from someone who knows what they are doing!
