RE: what type of solder to use
Hi!
The problem was the limited space behind the firewall on my Marutaka DC-3 as both the electric retracts (big 90mm wheels) and fuel tank had to fit.The only option I had was to custom make a steel tank (from 0,3mm K&S tin plate) that fitted tight against both the engine cowl and the firewall.
