RCU Forums - View Single Post - prop/reduction drive calculation
Old 02-19-2009 | 12:16 PM
gkamysz's Avatar
gkamysz
My Feedback: (19)
Default RE: prop/reduction drive calculation
This is easily calculated in a spread sheet program. Diameter changes to the square root of the ratio and pitch changes proportionally to the ratio for a given power and pitch speed. If you halve RPM, the prop diameter needs to increase by square root of 2 and pitch must be doubled to maintain the same engine load and pitch speed.
